LimeSDR Mini v2.4 Board¶
Introduction¶
LimeSDR Mini v2.4 Board Key Features¶
The LimeSDR-Mini is low-cost software defined radio board. LimeSDR-Mini development board provides a hardware platform for developing and prototyping high-performance and logic-intensive digital and RF designs based on Lattice Semiconductor’s ECP5 FPGA and Lime Microsystems transceiver.
Figure 1: LimeSDR Mini v2.4 board top view¶
Figure 2: LimeSDR Mini v2.4 board bottom view¶
LimeSDR Mini board features:
RF and BB parameters:
Configuration: SISO (1x TX, 1x RX)
Frequency range: 10 MHz – 3.5 GHz
Bandwidth: 30.72 MHz
Sample depth: 12 bit
Sample rate: 30.72 MSPS
Transmit power: max 10 dBm (depending on frequency)
USB 3.0 controller: FTDI FT601
FPGA: board is designed for Lattice ECP5 family LFE5U-25F/LFE5U-45F/LFE5U-85F FPGAs in 285-ball csfBGA package. By default board is assembled with LFE5U-45F-MG285 FPGA. Lattice ECP5 LFE5U-45F features:
285-pin csfBGA package (10 x 10 mm, 0.5 mm)
44 K LUTs logic capacity
108 sysMEM Blocks (18 Kb)
1944 Kb Embedded Memory
351 Kb distributed RAM
72x 18x18-bit multipliers
4x PLLs and 4x DLLs
118 IOs
FPGA configuration via JTAG
RF transceiver: Lime Microsystems LMS7002M
EEPROM Memory: 2x 128Kb EEPROMs for LMS MCU firmware and FPGA data (optional)
FLASH Memory: 128Mb Flash memory for FPGA configuration
Temperature sensor: LM75
3x Dual colour (RG) LEDs
8x + 2x FPGA GPIO pinheaders (3.3V) (optional)
Connections:
USB 3.0 (type A) plug
Coaxial RF (SMA female) connectors
FPGA GPIO headers (unpopulated)
FPGA JTAG connector (unpopulated)
FAN (5V default or 3.3V) connector
40.00MHz on board VCTCXO
VCTCXO can be tuned by onboard DAC
Reference clock input and output connectors (U.FL)
Analog switch for clock source selection
Board size: 69mm x 31.4mm
Board power source: USB connector (5V)
For more information on the following topics, refer to the corresponding documents:
Board Overview¶
The heart of the LimeSDR-Mini board is Lattice ECP5 (LFE5U-45F) FPGA. It’s main function is to transfer digital data between the PC through a USB 3.0 connector. The block diagram for LimeSDR-Mini board is presented in the Figure 3.
Figure 3: LimeSDR Mini v2.4 Development Board Block Diagram¶
This section contains component location description on the board. LimeSDR-Mini board picture with highlighted connectors and main components is presented in Figure 4 and Figure 5.
Figure 4: LimeSDR Mini v2.4 board top connectors and main components¶
Figure 5: LimeSDR Mini v2.4 board bottom connectors and main components¶
Featured Devices |
IC1 |
RF transceiver |
Lime Microsystems LMS7002M |
Lattice Semiconductor’s LFE5U (LFE5U-45F) |
IC8 |
USB 3.0 microcontroller |
FTDI USB 3.0 to FIFO interface bridge chip FT601 |
IC10 |
Temperature sensor LM75 |
Configuration, Status and Setup Elements |
JTAG chain connector |
FPGA programming pin header on the board edge for JTAG cable, 0.1” pitch |
LED1, LED2, LED3 |
User defined FPGA indication LED. |
General User Input/Output |
8x FPGA GPIOs, 3.3V, 0.05” pitch |
2x FPGA GPIOs on the board edge, 3.3V, 0.1” pitch |
5V (3.3V voltage can be chosen by resistors) fan connection pin headers, 0.1” pitch |
Memory Devices |
IC2 |
I²C EEPROM Memory 128Kb (16 x 8), connected to RF transceiver I2C bus |
IC12 |
I²C EEPROM Memory 128Kb (16K x 8), connected to FPGA I2C bus |
IC15 |
Quad SPI Flash Memory 128 Mb (16M x 8) connected to FPGA SPI |
USB 3.0 connector |
USB 3.0 (type A) plug |
40.00 MHz Voltage Controlled Temperature Compensated Crystal Oscillator |
IC11 |
10 bit DAC for TCXO (XT4) frequency tuning (default) |
IC16 |
16 bit DAC for TCXO (XT4) frequency tuning (unpopulated) |
Voltage reference (unpopulated) |
Analog switch |
Reference clock input |
IC14 |
Switching regulator LMZ20501 (1.8V rail) |
Switching regulator LMZ20501 (3.3V rail) |
Linear regulator LD39100PUR (1.1V rail) |
IC5 |
Linear regulator LD39100PUR (1.25V rail) |
IC6 |
Linear regulator LD39100PUR (1.4V rail) |
Linear regulator LD39100PUR (2.5V rail) |
Board Description¶
More detailed description of LimeSDR-Mini board components and interconnections is given in the sections of this chapter.
RF transceiver digital connectivity¶
The interface and control signals are described below:
Digital Interface Signals: LENS7002 is using data bus LIMNS_DIQ1_D[11:0] and LMS_DIQ2_D[11:0], LMS_EN_IQSEL1 and LMS_EN_IQSEL2, LMS_FCLK1 and LMS_FCLK2, LMS_MCLK1 and LMS_MCLK2 signals to transfer data to/from FPGA. Indexes 1 and 2 indicate transceiver digital data PORT-1 or PORT-2. Any of these ports can be used to transmit or receive data. By default PORT-1 is selected as transmit port and PORT-2 is selected as receiver port. The FCLK# is input clock and MCLK# is output clock for LMS7002M transceiver. TXNRX signals sets ports directions. For LMS7002M interface timing details refer to LMS7002M transceiver datasheet page 12-13.
LMS Control Signals: these signals are used for optional functionality:
LMS_RXEN, LMS_TXEN – receiver and transmitter enable/disable signals connected to FPGA Bank 8 (VDIO_LMS_FPGA; 2.5V).
LMS_RESET – LMS7002M reset connected to FPGA Bank 3 (VDIO_LMS_FPGA; 2.5V).
SPI Interface: LMS7002M transceiver is configured via 4-wire SPI interface; FPGA_SPI_SCLK, FPGA_SPI_MOSI, FPGA_SPI_MISO, FPGA_SPI_LMS_SS. The SPI interface controlled from FPGA Bank 3 (VDIO_LMS_FPGA; 2.5V).
LMS I2C Interface: can be used for LMS EEPROM content modifying or for debug purposes. The signals LMS_I2C_SCL, LMS_I2C_DATA connected to EEPROM.
Chip pin (IC1) |
Chip reference (IC1) |
FPGA I/O standard |
FPGA I/O standard |
E5 |
xoscin_tx |
TxPLL_CLK |
Connected to 40.00 MHz clock |
AB34 |
MCLK1 |
LMS_MCLK1 |
H4 |
2.5V/3.3V |
AA33 |
FCLK1 |
LMS_FCLK1 |
H3 |
2.5V/3.3V |
V32 |
TXNRX1 |
LMS_TXNRX1 |
F1 |
2.5V/3.3V |
U29 |
TXEN |
LMS_TXEN |
B7 |
2.5V/3.3V |
1Y32 |
ENABLE_IQSEL1 |
LMS_EN_IQSEL1 |
F3 |
2.5V/3.3V |
AG31 |
DIQ1_D0 |
LMS_DIQ1_D0 |
J2 |
2.5V/3.3V |
AF30 |
DIQ1_D1 |
LMS_DIQ1_D1 |
L1 |
2.5V/3.3V |
AF34 |
DIQ1_D2 |
LMS_DIQ1_D2 |
K1 |
2.5V/3.3V |
AE31 |
DIQ1_D3 |
LMS_DIQ1_D3 |
K4 |
2.5V/3.3V |
AD30 |
DIQ1_D4 |
LMS_DIQ1_D4 |
G3 |
2.5V/3.3V |
AC29 |
DIQ1_D5 |
LMS_DIQ1_D5 |
F4 |
2.5V/3.3V |
AE33 |
DIQ1_D6 |
LMS_DIQ1_D6 |
J1 |
2.5V/3.3V |
AD32 |
DIQ1_D7 |
LMS_DIQ1_D7 |
H1 |
2.5V/3.3V |
AC31 |
DIQ1_D8 |
LMS_DIQ1_D8 |
G4 |
2.5V/3.3V |
AC33 |
DIQ1_D9 |
LMS_DIQ1_D9 |
F2 |
2.5V/3.3V |
AB30 |
DIQ1_D10 |
LMS_DIQ1_D10 |
G1 |
2.5V/3.3V |
AB32 |
DIQ1_D11 |
LMS_DIQ1_D11 |
H2 |
2.5V/3.3V |
AM24 |
xoscin_rx |
RxPLL_CLK |
P34 |
MCLK2 |
LMS_MCLK2 |
D2 |
2.5V/3.3V |
R29 |
FCLK2 |
LMS_FCLK2 |
D1 |
2.5V/3.3V |
U31 |
TXNRX2 |
LMS_TXNRX2 |
V34 |
RXEN |
LMS_RXEN |
D6 |
2.5V/3.3V |
R33 |
ENABLE_IQSEL2 |
LMS_EN_IQSEL2 |
C4 |
2.5V/3.3V |
H30 |
DIQ2_D0 |
LMS_DIQ2_D0 |
A3 |
2.5V/3.3V |
J31 |
DIQ2_D1 |
LMS_DIQ2_D1 |
C2 |
2.5V/3.3V |
K30 |
DIQ2_D2 |
LMS_DIQ2_D2 |
A2 |
2.5V/3.3V |
K32 |
DIQ2_D3 |
LMS_DIQ2_D3 |
B4 |
2.5V/3.3V |
L31 |
DIQ2_D4 |
LMS_DIQ2_D4 |
C3 |
2.5V/3.3V |
K34 |
DIQ2_D5 |
LMS_DIQ2_D5 |
B2 |
2.5V/3.3V |
M30 |
DIQ2_D6 |
LMS_DIQ2_D6 |
D3 |
2.5V/3.3V |
M32 |
DIQ2_D7 |
LMS_DIQ2_D7 |
B1 |
2.5V/3.3V |
N31 |
DIQ2_D8 |
LMS_DIQ2_D8 |
A4 |
2.5V/3.3V |
N33 |
DIQ2_D9 |
LMS_DIQ2_D9 |
C1 |
2.5V/3.3V |
P30 |
DIQ2_D10 |
LMS_DIQ2_D10 |
C7 |
2.5V/3.3V |
P32 |
DIQ2_D11 |
LMS_DIQ2_D11 |
A6 |
2.5V/3.3V |
U33 |
CORE_LDO_EN |
LMS_CORE_LDO_EN |
C6 |
2.5V/3.3V |
E27 |
RESET |
LMS_RESET |
A7 |
2.5V/3.3V |
D28 |
SEN |
FPGA_SPI_LMS_SS |
N3 |
2.5V/3.3V |
SPI interface |
C29 |
SCLK |
FPGA_SPI_SCLK |
M3 |
2.5V/3.3V |
SPI interface |
F30 |
FPGA_SPI_MOSI |
L3 |
2.5V/3.3V |
SPI interface |
F28 |
SDO |
FPGA_SPI_MISO |
K3 |
2.5V/3.3V |
SPI interface |
D26 |
SDA |
LMS_I2C_SDA |
Connected to EEPROM |
C27 |
SCL |
LMS_I2C_SCL |
RF path and control signals¶
LimeSDR-Mini RF path contains matching networks, RF switches, loopback variable attenuator and 2 SMA connectors (J1 - TX and J2 - RX) as shown in Figure 6.
Figure 6: LimeSDR Mini v2.4 RF diagram¶
RF transceiver TX and RX ports has its dedicated matching network which together determines the working frequency range. More detailed information about RF transceiver ports and matching network frequency ranges is listed in the Table 3.
RF transceiver port |
TX1_1 |
2 GHz - 2.6 GHz |
TX1_2 |
30 MHz - 1.9 GHz |
RX1_H |
2 GHz - 2.6 GHz |
RX1_W |
700 MHz - 900 MHz |
RF path control signals are described in the Table 4.
RFSW_TX (SKY13411-374LF – IC3) |
RFSW_TX_V1 |
B10 |
V1 – high V2- low TX1_1 to TX and TX1_2 to ATT, V1 – low V2 – high TX1_1 to ATT and TX1_2 to TX |
RFSW_TX_V2 |
C9 |
RFSW_RX (SKY13411-374LF – IC3) |
RFSW_RX_V1 |
C11 |
V1 – high V2- low RX_H to RX and RX1_W to ATT, V1 – low V2 – high RX1_H to ATT and RX1_W to RX |
RFSW_RX_V2 |
B11 |
Variable attenuator |
TX_LB_AT |
C8 |
High - -40dB, low - -25dB |
TX_LB_SH |
B8 |
Attenuator shunting. |
USB 3.0 controller¶
Software controls LimeSDR Mini board via the USB 3.0 controller (FTDI USB 3.0 to FIFO interface bridge chip FT601). The controller signals description showed below:
FT_D[31:0] – FTDI 32-bit data interface is connected to FPGA.
FT_TXEn, FT_RXFn, FT_SIWUn, FT_WRn, FT_RDn, FT_OEn, FT_BE[3:0] – FTDI interface control signals.
FT_CLK – FTDI interface clock. Clock from FTDI is fed to FPGA.
More information about USB 3.0 controller (FTDI) pins, schematic signal names, FPGA interconnections and I/O standards is given in Table 5.
Chip pin (IC6) |
Chip reference (IC6) |
DATA_0 |
FT_D0 |
A13 |
DATA_1 |
FT_D1 |
B12 |
DATA_2 |
FT_D2 |
B15 |
DATA_3 |
FT_D3 |
C12 |
DATA_4 |
FT_D4 |
A16 |
DATA_5 |
FT_D5 |
A12 |
DATA_6 |
FT_D6 |
D18 |
DATA_7 |
FT_D7 |
B17 |
DATA_8 |
FT_D8 |
F15 |
DATA_9 |
FT_D9 |
D16 |
DATA_10 |
FT_D10 |
D15 |
DATA_11 |
FT_D11 |
C13 |
DATA_12 |
FT_D12 |
H18 |
DATA_13 |
FT_D13 |
B13 |
DATA_14 |
FT_D14 |
J18 |
DATA_15 |
FT_D15 |
A15 |
DATA_16 |
FT_D16 |
B18 |
DATA_17 |
FT_D17 |
C18 |
DATA_18 |
FT_D18 |
A17 |
DATA_19 |
FT_D19 |
K18 |
DATA_20 |
FT_D20 |
C15 |
DATA_21 |
FT_D21 |
L18 |
DATA_22 |
FT_D22 |
F18 |
DATA_23 |
FT_D23 |
C16 |
DATA_24 |
FT_D24 |
G16 |
DATA_25 |
FT_D25 |
D13 |
DATA_26 |
FT_D26 |
G18 |
DATA_27 |
FT_D27 |
F16 |
DATA_28 |
FT_D28 |
C17 |
DATA_29 |
FT_D29 |
F17 |
DATA_30 |
FT_D30 |
K15 |
DATA_31 |
FT_D31 |
K17 |
CLK |
FT_CLK |
D17 |
BE_0 |
FT_BE0 |
L15 |
BE_1 |
FT_BE1 |
J17 |
BE_2 |
FT_BE2 |
K16 |
BE_3 |
FT_BE3 |
H17 |
TXE_N |
FT_TXEn |
M16 |
RXF_N |
FT_RXFn |
H16 |
SIWU_N |
FT_SIWUn |
10k pull up |
WR_N |
FT_WRn |
J16 |
RD_N |
FT_RDn |
H15 |
OE_N |
FT_OEn |
L16 |
RESET_N |
FT_RESETn |
M17 |
WAKEP_N |
FT_WAKEUPn |
G15 |
Indication LEDs¶
LimeSDR Mini board comes with three dual colour (red and green (RG)) indication LEDs. These LEDs are soldered on the top of the board near RF connectors.
Figure 7: LimeSDR Mini v2.4 indication LEDs (top and bottom)¶
LEDs are connected to FPGA and their function may be programmed according to the user requirements. Default function of LEDs and related information is listed in Table 6.
Board reference |
Board label |
FPGA_LED1_R |
V17 |
Board status: Blinking green = LMK_CLK clock is running; Red = USB control port is active. |
FPGA_LED1_G |
R16 |
FPGA_LED2_R |
R18 (FPGA_GPIO5) |
RX status: Green = DIQ data receive enabled; Off = DIQ data receive disabled. Shared with FPGA_GPIO4 and FPGA_GPIO5. |
FPGA_LED2_G |
M18 (FPGA_GPIO4) |
FPGA_LED3_R |
R17 (FPGA_GPIO7) |
TX status: Red = transmitting DIQ data; Off = no activity. Shared with FPGA_GPIO6 and FPGA_GPIO7. |
FPGA_LED3_G |
T17 (FPGA_GPIO6) |
Low speed interfaces¶
In Table 7, Table 8 and Table 9 are listed FPGA_SPI pins, schematic signal names, FPGA interconnections and I/O standards.
FPGA_SPI_SCLK |
M3 |
2.5V /3.3V |
FPGA_SPI_MOSI |
L3 |
2.5V /3.3V |
FPGA_SPI_MISO |
K3 |
2.5V /3.3V |
FPGA_SPI_LMS_SS |
N3 |
2.5V /3.3V |
IC1 (LMS7002) SPI slave select (FPGA output) |
FPGA_SPI_DAC_SS |
L4 |
2.5V /3.3V |
IC11 SPI slave select (FPGA output) |
In the table below are listed FPGA_CFG_SPI pins, schematic signal names, FPGA interconnections and I/O standards.
FPGA_CFG_SPI_SCLK |
U16 |
FPGA_CFG_SPI_MOSI |
U18 |
FPGA_CFG_SPI_MISO |
T18 |
FPGA_CFG_SPI_SS |
U17 |
IC15 SPI slave select (FPGA output) |
In the table below are listed FPGA_I2C interface slave devices and their other information.
I2C slave device |
IC10 |
1 0 0 1 0 0 0 RW |
IC12 |
M24128 |
GPIO connectors¶
8 GPIOs from FPGA are connected to 10 pin 0.05” header. Additional 2 pins are dedicated for power. FPGA_GPIO[7:4] are shared with TX and RX LEDs. Remove solder from solder bridges to disconnect LEDs from GPIOs lines. In Table 10 is listed FPGA_GPIO (J3) information.
FPGA_GPIO0 |
N15 |
FPGA_GPIO1 |
N18 |
FPGA_GPIO2 |
N16 |
FPGA_GPIO3 |
N17 |
FPGA_GPIO4 |
M18 |
Shared with FPGA_LED2_G |
FPGA_GPIO5 |
R18 |
Shared with FPGA_LED2_R |
FPGA_GPIO6 |
T17 |
Shared with FPGA_LED3_G |
FPGA_GPIO7 |
R17 |
Shared with FPGA_LED3_R |
Ground pin |
Selectable power net (3.3V or 5V). Default 3.3V |
Another 2 GPIOs are connected to 5 header on the board edge. In Table 11 is listed FPGA_EGPIO (J4) information.
Ground pin |
FPGA_EGPIO0 |
A10 |
FPGA_EGPIO1 |
A8 |
Power net (3.3V) |
Power net (5.0V) |
JTAG interface¶
To debug FPGA design, flash bitstream to FPGA and/or Flash memory JTAG is used. It is located on the PCB top side (see Figure 4: LimeSDR Mini v2.4 board top connectors and main components) and attaches to the programmer using 7-pin, 0.1” spaced JTAG connector J5. JTAG connector pins, schematic signal names, FPGA interconnections and I/O standards are listed in Table 12.
Ground |
TCK |
U13 |
Test Clock |
TDO |
V14 |
Test Data Out |
TMS |
V13 |
Test Mode Select |
TDI |
T13 |
Test Data In |
Power (3.3V) |
Power (5.0V) |
More information about JTAG programming can be found in JTAG Programming.
Board temperature control¶
LimeSDR-Mini has integrated temperature sensor which controls FAN to keep board in operating temperature range. FAN must be connected to J9 (0.1” pitch) connector. FAN control voltage y default is 5V, but it can be changed to 3.3V by resistors.
Fan will be turned on if board will heat up to 55°C and FAN will be turned off if board will cool down to 45°C.
Figure 8: FAN control temperature hysteresis¶
Clock distribution¶
LimeSDR-Mini board clock distribution block diagram is presented in Figure 9. LimeSDR-Mini board has onboard 40.00 MHz VCTCXO that is reference clock for RF transceiver and FPGA PLLs. Board clock distribution block diagram is presented in Figure 9.
Figure 9: LimeSDR Mini v2.4 board clock distribution block diagram¶
Rakon E7355LF 40 MHz voltage controlled temperature compensated crystal oscillator (VCTCXO) is main board clock source. VCTCXO frequency can be tuned by using DAC (IC11 10 bit or IC16 16 bit (unpopulated)). Main VCTCXO parameters are listed in Table 13.
Frequency parameter |
Value |
Calibration (25°C ± 1°C) |
± 1 ppm max |
Stability (-40 to 85 °C) |
± 0.5 max |
Long term stability (1 year, 10 years) |
± 2 ppm max, ± 4 ppm max |
Control voltage range |
0.5V .. 2.5V |
Frequency tuning |
± 7 ppm min, ± 15 ppm max |
Slope |
+9 ppm/V |
VCTCXO clock and external reference clock connector J8 (REF_CLK_IN) are connected to analog switch for clock source selection. Selected clock source is fed to clock buffer IC9. Buffered clock is connected to RF transceiver and FPGA. Buffered clock is also connected to connector J7 (REF_CLK_OUT) and can be fed to external hardware for synchronisation.
Main board clock lines and other related information are listed in Table 14
Source |
External |
REF_CLK_IN |
2.5V/3.3V |
External reference clock input |
Clock buffer (IC9) |
REF_CLK_OUT |
LMK_CLK |
A9 |
Reference clock connected to FPGA |
RF transceiver (IC1) |
RxPLL_CLK |
1.8V |
TxPLL_CLK |
1.8V |
LMS_MCLK1 |
2.5V/3.3V |
H4 |
LMS_FCLK1 |
2.5V/3.3V |
H3 |
LMS_MCLK2 |
2.5V/3.3V |
D2 |
LMS_FCLK2 |
2.5V/3.3V |
D1 |
USB 3.0 controller (IC8) |
FT_CLK |
D17 |
Clock output (100 MHz) from USB controller |
Power distribution¶
LimeSDR-Mini board is powered from USB port (5V). LimeSDR-Mini board power delivery network consists of different power rails with different voltages, filters, power sequences. LimeSDR-Mini board power distribution block diagram is presented in Figure 10.
Figure 12: LimeSDR Mini v2.4 board power distribution block diagram¶
